application show
(DEPRECATED)-Display applications
This command is deprecated and may be removed in a future release of Data ONTAP. Use the REST interface instead. |
This command displays applications. An application groups storage objects to perform application-granular operations.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected application.
[-vserver <vserver name>]- Vserver-
Selects applications belonging to Vservers that match the parameter value.
[-application <text>]- Application-
Selects applications with names that match the parameter value.
cluster1::> application show
Vserver Application
vs1 app1
app2
app3
app4
4 entries were displayed.
The example above displays all applications in the cluster.
