metrocluster configuration-settings connection show
Display the connections between partner nodes in a MetroCluster setup
The metrocluster configuration-settings connection show command displays the connection configuration information between the nodes in a MetroCluster setup.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>]- DR Group ID-
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>]- Cluster UUID-
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
[-cluster <Cluster name>]- Cluster Name-
If this parameter is specified, the command displays information for the matching cluster.
[-node-uuid <UUID>]- Node UUID-
If this parameter is specified, the command displays information for the matching node specified by uuid.
[-node <text>]- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
[-home-port {<netport>|<ifgrp>}]- Home Port-
If this parameter is specified, the command displays information for the matching home-port.
[-relationship-type <Roles of MetroCluster Nodes>]- Relationship Role Type-
If this parameter is specified, the command displays information for the matching relationship-type.
[-source-address <IP Address>]- Source Network Address-
If this parameter is specified, the command displays information for the matching source address.
[-destination-address <IP Address>]- Destination Network Address-
If this parameter is specified, the command displays information for the matching destination address.
[-partner-cluster-uuid <UUID>]- Partner Cluster UUID-
If this parameter is specified, the command displays information for the matching partner-cluster-uuid.
[-partner-node-uuid <UUID>]- Partner Node UUID-
If this parameter is specified, the command displays information for the matching partner-node-uuid.
[-partner-node <text>]- Partner Node Name-
If this parameter is specified, the command displays information for the matching partner-node.
[-partner-type <text>]- Partner Relationship Type-
If this parameter is specified, the command displays information for the matching partner-type.
[-config-state <text>]- Configuration State-
If this parameter is specified, the command displays information for the matching config-state.
[-config-error-info <text>]- Configuration Error Information-
If this parameter is specified, the command displays information for the matching config-error-info.
The following example shows the output of metrocluster configuration-settings connection connect command:
Output of the command before the connections are established using the link:metrocluster-configuration-settings-connection-connect.html[metrocluster configuration-settings connection connect] command:
clusA::> metrocluster configuration-settings connection show
DR Source Destination
Group Cluster Node Network Address Network Address Partner Type Config State
1 clusA A1
Home Port: e0f
10.140.113.214 10.140.113.216 HA Partner disconnected
Home Port: e0f
10.140.113.214 10.140.113.218 DR Partner disconnected
Home Port: e0f
10.140.113.214 10.140.113.249 DR Auxiliary disconnected
Home Port: e0g
10.140.113.215 10.140.113.217 HA Partner disconnected
Home Port: e0g
10.140.113.215 10.140.113.248 DR Partner disconnected
Home Port: e0g
10.140.113.215 10.140.113.25 DR Auxiliary disconnected
A2
Home Port: e0f
10.140.113.216 10.140.113.214 HA Partner disconnected
Home Port: e0f
10.140.113.216 10.140.113.249 DR Partner disconnected
Home Port: e0f
10.140.113.216 10.140.113.218 DR Auxiliary disconnected
Home Port: e0g
10.140.113.217 10.140.113.215 HA Partner disconnected
Home Port: e0g
10.140.113.217 10.140.113.25 DR Partner disconnected
Home Port: e0g
10.140.113.217 10.140.113.248 DR Auxiliary disconnected
clusB B2
Home Port: e0f
10.140.113.249 10.140.113.218 HA Partner disconnected
Home Port: e0f
10.140.113.249 10.140.113.216 DR Partner disconnected
Home Port: e0f
10.140.113.249 10.140.113.214 DR Auxiliary disconnected
Home Port: e0g
10.140.113.25 10.140.113.248 HA Partner disconnected
Home Port: e0g
10.140.113.25 10.140.113.217 DR Partner disconnected
Home Port: e0g
10.140.113.25 10.140.113.215 DR Auxiliary disconnected
B1
Home Port: e0f
10.140.113.218 10.140.113.249 HA Partner disconnected
Home Port: e0f
10.140.113.218 10.140.113.214 DR Partner disconnected
Home Port: e0f
10.140.113.218 10.140.113.216 DR Auxiliary disconnected
Home Port: e0g
10.140.113.248 10.140.113.25 HA Partner disconnected
Home Port: e0g
10.140.113.248 10.140.113.215 DR Partner disconnected
Home Port: e0g
10.140.113.248 10.140.113.217 DR Auxiliary disconnected
24 entries were displayed.
Output of the command after the connections are established using the link:metrocluster-configuration-settings-connection-connect.html[metrocluster configuration-settings connection connect] command:
1 clusA A1
Home Port: e0f
10.140.113.214 10.140.113.216 HA Partner completed
Home Port: e0f
10.140.113.214 10.140.113.218 DR Partner completed
Home Port: e0f
10.140.113.214 10.140.113.249 DR Auxiliary completed
Home Port: e0g
10.140.113.215 10.140.113.217 HA Partner completed
Home Port: e0g
10.140.113.215 10.140.113.248 DR Partner completed
Home Port: e0g
10.140.113.215 10.140.113.25 DR Auxiliary completed
A2
Home Port: e0f
10.140.113.216 10.140.113.214 HA Partner completed
Home Port: e0f
10.140.113.216 10.140.113.249 DR Partner completed
Home Port: e0f
10.140.113.216 10.140.113.218 DR Auxiliary completed
Home Port: e0g
10.140.113.217 10.140.113.215 HA Partner completed
Home Port: e0g
10.140.113.217 10.140.113.25 DR Partner completed
Home Port: e0g
10.140.113.217 10.140.113.248 DR Auxiliary completed
clusB B2
Home Port: e0f
10.140.113.249 10.140.113.218 HA Partner completed
Home Port: e0f
10.140.113.249 10.140.113.216 DR Partner completed
Home Port: e0f
10.140.113.249 10.140.113.214 DR Auxiliary completed
Home Port: e0g
10.140.113.25 10.140.113.248 HA Partner completed
Home Port: e0g
10.140.113.25 10.140.113.217 DR Partner completed
Home Port: e0g
10.140.113.25 10.140.113.215 DR Auxiliary completed
B1
Home Port: e0f
10.140.113.218 10.140.113.249 HA Partner completed
Home Port: e0f
10.140.113.218 10.140.113.214 DR Partner completed
Home Port: e0f
10.140.113.218 10.140.113.216 DR Auxiliary completed
Home Port: e0g
10.140.113.248 10.140.113.25 HA Partner completed
Home Port: e0g
10.140.113.248 10.140.113.215 DR Partner completed
Home Port: e0g
10.140.113.248 10.140.113.217 DR Auxiliary completed
