volume file clone deletion modify
The volume file clone deletion modify
command can be used to change the required minimum clone file size of a volume for clone delete.
-vserver <vserver name>
- Vserver Name-
Name of the vserver.
-volume <volume name>
- Volume Name-
Name of the volume.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}]
- Minimum Size Required for Clone delete-
Minimum clone file size required for clone delete.
The following example changes the required minimum file size to 100M for volume vol1
of vserver _ vs1 _
cluster1::> volume file clone deletion modify -volume vol1 -vserver vs1 -minimum-size 100M
