      system snmp community show
Displays communities
Displays the current list of SNMP communities.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the Vserver to which the SNMP community belongs
 [-community-name <text>]- Community-
Selects the SNMP v1/v2c community string
 [-access <ctype>]- access-
Selects the access type of the SNMP v1/v2c community. Read-only (ro) is the only access type supported
cluster1::> system snmp community show
cluster1
    ro private
