metrocluster check aggregate show
Show results of MetroCluster check for aggregates
The metrocluster check aggregate show command displays the results of aggregate checks performed by the metrocluster check run command.
The command verifies the following aspects of the configuration of all aggregates in MetroCluster:
  • mirroring-status: This check verifies that the aggregate is mirrored.
  • disk-pool-allocation: This check verifies that the disks belonging to this aggregate have been correctly allocated to the right pools.
Additional information about the warnings (if any) and recovery steps can be viewed by running the command with the -instance option.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <Node name>] - Node Name
This is the name of the node for which the check was run. If this parameter is specified, only rows with this node will be displayed.
[-aggregate <aggregate name>] - Name of the Aggregate
This is the name of the aggregate for which the check was run. If this parameter is specified, only rows with this aggregate will be displayed.
[-check <MetroCluster Aggregate Check>] - Type of Check
This is the type of the check performed. If this parameter is specified, only rows with this check will be displayed.
[-cluster <Cluster name>] - Name of Cluster
This is the name of the cluster the node belongs to. If this parameter is specified, only rows with this cluster will be displayed.
[-result {ok|warning|not-run|not-applicable}] - Result of the Check
This is the result of the check. If this parameter is specified, only rows with this result will be displayed.
[-additional-info <text>,…​] - Additional Information/Recovery Steps
This is additional information about the check. This field has more information and recovery steps for the warning. If this parameter is specified, only rows with this additional info will be displayed.
The following example shows the execution of the command in a MetroCluster configuration with two nodes per cluster:
clusA::> metrocluster check aggregate show
Last Checked On: 4/9/2014 20:11:46
Node                  Aggregate             Check                 Result
clusA-01              a1_required_data_aggr
                                            mirroring-status      ok
                                            disk-pool-allocation  ok
                      aggr0_a1
                                            mirroring-status      ok
clusA-02              a2_required_data_aggr
                                            mirroring-status      ok
                      aggr0_a2
                                            mirroring-status      ok
clusB-01              b1_required_data_aggr
                                            mirroring-status      ok
                      aggr0_b1
                                            mirroring-status      ok
clusB-02              aggr0_b2
                                            mirroring-status      ok
                      b2_required_data_aggr
                                            mirroring-status      ok
16 entries were displayed.
The following example shows the execution of the command with -instance option:
clusA::> metrocluster check aggregate show -instance
Node Name: clusA-01
                Name of the Aggregate: a1_required_data_aggr_1
                        Type of Check: mirroring-status
                      Name of Cluster: clusA
                  Result of the Check: ok
Additional Information/Recovery Steps: -
Node Name: clusA-01
                        Type of Check: disk-pool-allocation
Node Name: clusA-01
                Name of the Aggregate: a1_required_data_aggr_2
Node Name: clusA-01
Node Name: clusA-01
                Name of the Aggregate: aggr0_a1
                  Result of the Check: warning
Additional Information/Recovery Steps: Root aggregate "aggr0_a1" is un-mirrored. Root aggregates should be mirrored in a MetroCluster configuration.
Node Name: clusA-01
Node Name: clusB-01
                Name of the Aggregate: aggr0_b1
                      Name of Cluster: clusB
Node Name: clusB-01
Node Name: clusB-01
                Name of the Aggregate: b1_required_data_aggr_1
Node Name: clusB-01
Node Name: clusB-01
                Name of the Aggregate: b1_required_data_aggr_2
Node Name: clusB-01
12 entries were displayed.
