vserver nvme subsystem map show
Display namespace maps within the subsystem
The vserver nvme subsystem map show command displays information about NVMe subsystem maps.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the NVMe subsystem maps that match the Vserver that you specify.
[-subsystem <text>]- Subsystem-
Use this parameter to display the NVMe subsystem maps that match the subsystem that you specify.
[-nsid <Hex 32bit Integer>]- NSID-
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace NSID that you specify.
[-path <path>]- Namespace Path-
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace path that you specify.
[-anagrpid <Hex 32bit Integer>]- ANA Group ID (privilege: advanced)-
Use this parameter to display the NVMe namespaces that match the Asymmetric Namespace Access (ANA) group identifier that you specify.
[-namespace-uuid <UUID>]- Namespace UUID-
Use this parameter to display the NVMe ubsystem maps that match the NVMe namespace UUID that you specify.
cluster-1::*> vserver nvme subsystem map show -vserver vs_1
Vserver Subsystem NSID Namespace Path
vs_1 sub_1
1 /vol/nsvol1/ns1
2 /vol/nsvol1/ns2
2 entries were displayed.
