qos statistics workload performance show
Display system performance data per QoS workload
The qos statistics workload performance show command shows the current system performance that each QoS workload is achieving.
The command displays the following data:
The QoS workload name (Workload)
The QoS workload ID (ID)
Input/output operations performed per second (IOPS)
Throughput in kilobytes per second (KB/s) or megabytes per second (MB/s) as appropriate (Throughput)
Latency observed per request in microseconds (us) or milliseconds (ms) as appropriate (Latency)
The results displayed per iteration are sorted by IOPS. Each iteration starts with a row that displays the total IOPS used across all QoS workloads. Other columns in this row are either totals or averages.
[-node {<nodename>|local}]- Node-
Selects the QOS workloads that match this parameter value. If you do not specify this parameter, the command displays data for the entire cluster.
[-iterations <integer>]- Number of Iterations-
Specifies the number of times the display is refreshed before terminating. If you do not specify this parameter, the command iterates until interrupted by Ctrl-C.
[-refresh-display {true|false}]- Toggle Screen Refresh Between Each Iteration-
Specifies the display style. If true, the command clears the display after each data iteration. If false, the command displays each data iteration below the previous one. The default is false.
[-rows <integer>]- Number of Rows in the Output -
Specifies the number of busiest QoS policy groups to display. Valid values are from 1 to 20. The default value is 10.
[-policy-group <text>]- QoS Policy Group Name-
Selects the QoS workloads that belong to the QoS policy group specified by this parameter value. If you do not specify this parameter, the command displays data for all QoS workloads.
[-workload <text>]- QoS Workload Name -
Selects the QoS workload that match this parameter value. If you do not specify this parameter, the command displays data for all QoS workloads.
[-workload-id <integer>]- QoS Workload ID } -
Selects the QoS workload that match the QoS workload ID specified by this parameter value.
[-show-flexgroup-as-constituents {true|false}]- Display Flexgroups as Constituents-
If the parameter is specified and if the value is true, it will display data for FlexVols and Flexgroup Constituents. Otherwise it will display data for FlexVols and Flexgroups.
cluster1::> qos statistics workload performance show -iterations 100 -rows 4 Workload ID IOPS Throughput Latency --------------- ------ -------- ---------------- ---------- -total- - 97 1.90MB/s 216.87ms _Scan_Besteff.. 101 31 0KB/s 0ms vol_2-wid104 104 28 1.75MB/s 412.78ms vol_1-wid103 103 25 100.00KB/s 169.16ms vs1vol0-wid102 102 13 52.00KB/s 403.78ms -total- - 98 1276.00KB/s 89.98ms _Scan_Besteff.. 101 34 0KB/s 0ms vs1vol0-wid102 102 28 112.00KB/s 80.70ms vol_1-wid103 103 19 76.00KB/s 114.72ms vol_2-wid104 104 17 1088.00KB/s 257.60ms -total- - 78 1152.00KB/s 225.22ms _Scan_Besteff.. 101 30 0KB/s 0ms vol_1-wid103 103 17 68.00KB/s 452.27ms vol_2-wid104 104 16 1024.00KB/s 419.93ms vs1vol0-wid102 102 15 60.00KB/s 210.63ms
The example above displays the system performance for the 4 QoS workloads with the highest IOPS and it refreshes the display 100 times before terminating.
cluster1::> qos statistics workload performance show -iterations 100 -rows 2 -policy-group pg1 Workload ID IOPS Throughput Latency --------------- ------ -------- ---------------- ---------- -total- - 2598 9.96MB/s 1223.00us file-testfile.. 4228 650 2.54MB/s 1322.00us file-testfile.. 11201 635 2.48MB/s 1128.00us -total- - 2825 10.89MB/s 714.00us file-testfile.. 4228 707 2.76MB/s 759.00us file-testfile.. 11201 697 2.72MB/s 693.00us -total- - 2696 10.13MB/s 1149.00us file-testfile.. 4228 645 2.52MB/s 945.00us file-testfile.. 6827 634 2.48MB/s 1115.00us
The example above displays the system performance for the 2 QoS workloads belonging to QoS policy group pg1 with the highest IOPS and it refreshes the display 100 times before terminating.
cluster1::> qos statistics workload performance show -iterations 100 -workload-id 11201 Workload ID IOPS Throughput Latency --------------- ------ -------- ---------------- ---------- -total- - 2866 10.92MB/s 905.00us file-testfile.. 11201 674 2.63MB/s 889.00us -total- - 2761 10.55MB/s 1054.00us file-testfile.. 11201 638 2.49MB/s 1055.00us -total- - 2810 10.58MB/s 832.00us file-testfile.. 11201 685 2.68MB/s 909.00us -total- - 2593 9.86MB/s 1092.00us file-testfile.. 11201 632 2.47MB/s 964.00us
The example above displays the system performance for the QoS workload with QoS workload ID 11201 and it refreshes the display 100 times before terminating.
