storage failover show-takeover
Display takeover status
The storage failover show-takeover
command displays information about the takeover status of nodes in a cluster. The command also displays the takeover status of aggregates being taken over. During each phase of takeover, the takeover node and the node being taken over display their takeover status and the status of the aggregates being taken over. The command displays the following information when no parameters are specified:
Node name
Node takeover status - This contains a descriptive information about the phase of takeover.
Aggregate
Aggregate takeover status - This contains the following information:
Takeover status of the aggregate, such as "Done", "Failed", "In progress" and "Not attempted yet".
Reason for an aggregate takeover failure.
Corrective action, in case of an aggregate takeover failure.
You can specify additional parameters to display only the information that matches those parameters. For example, to display information only about a particular node, run the command with the `-node```_node_name_`` parameter.
[-fields <fieldname>,…]
If this parameter is specified, the command displays the specified fields for all nodes, in column style output.
[-instance ]
If this parameter is specified, the command displays the same detailed information as for the
-node
parameter, but for all nodes. [-node {<nodename>|local}]
- Node Name-
If this parameter is specified, the command displays information about the takeover status of the specified node, and the takeover status of the aggregates being taken over.
[-node-takeover-status <text>]
- Node’s Takeover Status-
If this parameter is specified, the command displays information about the takeover status of the nodes with the specified node-takeover-status. The command also displays the takeover status of the aggregates belonging to the node being taken over.
[-aggregate <text>]
- Aggregate Being Taken Over-
If this parameter is specified, the command displays information about the takeover status of the specified aggregate, and the takeover status of the nodes containing the specified aggregate.
[-aggregate-takeover-status <text>]
- Aggregate’s Takeover Status-
If this parameter is specified, the command displays information about the takeover status of the aggregates with the specified aggregate takeover status, and the takeover status of the nodes containing those aggregates.
The following example shows the takeover status of two nodes, nodeA and nodeB, in an High Availability (HA) pair, when both are in normal mode; neither node has taken over its HA partner. In this case, there is no takeover status for the aggregates.
cluster1::> storage failover show-takeover Node Node Status Aggregate Takeover Status ---------- --------------------- -------------- ------------------------------- nodeA Takeover not attempted. - - nodeB Takeover not attempted. - -
The following example shows the takeover status of two nodes, nodeA and nodeB, in an HA pair, when nodeA is in the SFO phase of an optimized takeover of nodeB. In this case, nodeA does not have information about the takeover status of nodeB’s aggregates.
cluster1::> storage failover show-takeover Node Node Status Aggregate Takeover Status ---------- --------------------- -------------- ------------------------------- nodeA Optimized takeover of partner in progress. Partner, ("nodeB"), is relocating its SFO aggregates. Run the command "storage failover show-takeover -node nodeB" to display the relocation status of the partner. - - nodeB Being taken over. aggr1 In progress, Module: backup. aggr2 Not attempted yet CFO aggregates Not attempted yet.
The following example shows the takeover status of two nodes, nodeA and nodeB, in an HA pair, when nodeA has completed the SFO phase of an optimized takeover of nodeB (but has not completed the CFO phase of the optimized takeover). In this case, nodeA has information about the takeover status of nodeB’s aggregates.
cluster1::> storage failover show-takeover ode Node Status Aggregate Takeover Status --------- --------------------- -------------- ------------------------------- odeA Partner has relocated its aggregates. Takeover in progress. aggr1 Done aggr2 Done CFO aggregates In progress. odeB Relocated aggregates to partner. Waiting for partner to takeover. aggr1 Done aggr2 Done CFO aggregates Not attempted yet.
The following example shows the takeover status of two nodes, nodeA and nodeB, in an HA pair, when nodeA has completed the SFO and CFO phases of an optimized takeover of nodeB. In this case, nodeA has information about the takeover status of nodeB’s aggregates. Since nodeB is not operational, an Remote Procedure Call(RPC) error is indicated in the command output.
cluster1::> storage failover show-takeover ode Node Status Aggregate Takeover Status --------- --------------------- -------------- ------------------------------- odeA Partner has relocated its aggregates. In takeover. aggr1 Done aggr2 Done CFO aggregates Done. arning: Unable to list entries on node nodeB. RPC: Port mapper failure - RPC: Timed out
The following example shows the takeover status of two nodes, nodeA and nodeB, in an HA pair, when nodeA has aborted the SFO phase of an optimized takeover of nodeB. In this case, nodeA does not have information about the takeover status of nodeB’s aggregates.
cluster1::> storage failover show-takeover ode Node Status Aggregate Takeover Status --------- --------------------- -------------- ------------------------------- odeA Optimized takeover of partner aborted. Run the command "storage failover show-takeover -node nodeB" to display the relocation status of the partner. - - odeB Optimized takeover by partner aborted. aggr1 Failed: Destination node did not online the aggregate on time. To takeover the remaining aggregates, run the "storage failover takeover -ofnode nodeB -bypass-optimization true" command. To giveback the relocated aggregates, run the "storage failover giveback -ofnode nodeB" command. aggr2 Not attempted yet CFO aggregates Not attempted yet.
