system services web show
Display the cluster-level configuration of web protocols
This command displays the overall availability of web services in the cluster, including the core protocol configurations for those services. In a pre-root or unclustered scenario, its output applies to the local node. The following information explains the External Web Services and Status attributes, two features of web services' availability.
The External Web Services field indicates whether remote clients are allowed to access the HTTP or HTTPS service content. Along with the system services firewall configuration, the External Web Services field indicates the visibility for client connections.
The Status field describes the aggregated operational state of cluster-level web services as retrieved from the system services web node command. The Status field does not reflect whether the protocols are externally visible, but whether the server processes are running correctly. For detailed information about individual servers, use the system services web node show command. The following are the possible values for the Status in node configuration or availability:
online, all web services are consistently configured and working correctly.
partial, one or more nodes' web services are unavailable due to an error condition.
mixed, the nodes in the cluster do not share the same web services configuration. This situation might occur if individual nodes were reconfigured with the
system services web nodecommand. -
offline, all of the nodes' web services are unavailable due to an error condition.
unclustered, the current node is not part of an active cluster.
The HTTP Enabled field indicates whether HTTP is enabled.
The following example displays the availability of web services for the cluster.
cluster1::> system services web show
 External Web Services: true
                Status: online
    HTTP Protocol Port: 80
   HTTPS Protocol Port: 443
          HTTP Enabled: true
