vserver migrate cleanup
Remove migrating entity
This command cleans up the migrate destination Vserver. If the Vserver migrate operation has failed or is paused, use this command to delete the destination Vserver.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
Name of the Vserver which is being migrated.
cluster1::> vserver migrate cleanup -vserver test
