      network ndp default-router delete-all
Delete default routers on a given IPspace
The network ndp default-router delete-all command deletes default router lists from the specified IPspace.
-ipspace <IPspace>- IPspace Name (privilege: advanced)-
Use this parameter to specify the IPspace where the default routers are to be deleted.
The following example deletes default routers from IPspace ips1.
cluster1::*> network ndp default-router delete-all -ipspace ips1
