vserver peer show
Display Vserver peer relationships
The vserver peer show command displays the following information about Vserver peer relationships:
  • Local Vserver name
  • Peer Vserver name
  • Local Vserver UUID
  • Peer Vserver UUID
  • Peer cluster name
  • State of the peering relationship
  • Applications
  • Remote Vserver name
{ [-fields <fieldname>,…​]
| [-instance ] }
