      system configuration recovery cluster modify
Modify cluster recovery status
The system configuration recovery cluster modify command modifies the cluster recovery status. This command should be used to end the cluster recovery after all recovery procedures are applied.
[-recovery-status {complete|in-progress|not-in-recovery}]- Cluster Recovery Status (privilege: advanced)-
Use this parameter with the value
completeto set the cluster recovery status after the cluster has been recreated and all of the nodes have been rejoined to it. This enables each node to resume normal system operations. Thein-progressandnot-in-recoveryvalues are not applicable to this command.
The following example modifies the cluster recovery status.
source::> system configuration recovery cluster modify -recovery-status complete
