ONTAP commands
security session request-statistics show-by-location
Show session request statistics by location
The security session request-statistics show-by-location command shows historical statistics for management session activity, categorized by client location.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the sessions that match this parameter value. This identifies the node that processed the session.
[-interface {cli|ontapi|rest}] - Interface
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) that processed the session.
[-location <text>] - Client Location
Selects the sessions that match this parameter value. This identifies the location of the calling client application. This is typically the IP address of the calling client, or "console" or "localhost" for console or localhost connections.
[-ipspace <IPspace>] - IPspace of Location
Selects the sessions that match this parameter value. This identifies the IPspace of the client location.
[-total <integer>] - Total Requests
Selects the sessions that match this parameter value. This identifies the total number of requests that have been made on a session. The following commands are not counted: top, up, cd, rows, history, exit.
[-blocked <integer>] - Blocked Requests
Selects the sessions that match this parameter value. This identifies the number of requests that were blocked due to configured limits.
[-failed <integer>] - Failed Requests
Selects the sessions that match this parameter value. This identifies the number of requests that failed for any reason (including if they were blocked by configured limits).
[-max-time <integer>] - Maximum Time (ms)
Selects the sessions that match this parameter value. This identifies the maximum amount of time (in milliseconds) that any request took.
[-last-time <integer>] - Last Time (ms)
Selects the sessions that match this parameter value. This identifies the amount of time (in milliseconds) that the last request took.
[-active <integer>] - Number Active Now
Selects the sessions that match this parameter value. This identifies the number of currently active sessions.
[-max-active <integer>] - Max Number Active
Selects the sessions that match this parameter value. This identifies the maximum number of concurrently active sessions.
[-last-active-seconds <integer>] - Seconds Since Last Session Start
Selects the sessions that match this parameter value. When a session is active, this indicates the time (in seconds) since the last session started.
[-idle-seconds <integer>] - Idle Seconds
Selects the sessions that match this parameter value. When no sessions are active, this indicates the time (in seconds) since the last session ended.
[-total-seconds <integer>] - Total Seconds
Selects the sessions that match this parameter value. This identifies the total time (in seconds) that have been taken by all completed requests; it does not include session idle time.
[-average-time <integer>] - Average Time (ms)
Selects the sessions that match this parameter value. This identifies the mean time spent processing requests.
[-success-percent <percent>] - Success Percent
Selects the sessions that match this parameter value. This identifies the percentage of successful requests.
[-blocked-percent <percent>] - Blocked Percent
Selects the sessions that match this parameter value. This identifies the percentage of requests that were blocked due to configured limits.
[-failed-percent <percent>] - Failed Percent
Selects the sessions that match this parameter value. This identifies the percentage of requests that failed for any reason (including if they were blocked by configured limits).
[-max-active-limit <integer>] - Max-Active Limit (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying historical statistics for all management session activity across the cluster, categorized by location.
cluster1::> security session request-statistics show-by-location
Node: node1               Interface: cli                 Idle    Total
Location          IPspace    Total Now Max Pass Fail  Seconds  Seconds Avg (ms)
console           Default       21   1   1 100%    0        -      127     6063
localhost         Default     2523   0   5  95%  115       20      280      111
Node: node1               Interface: ontapi              Idle    Total
10.98.17.254      Default        2   0   1 100%    0     2419        0       18
Node: node2               Interface: cli                 Idle    Total
console           Default        6   0   1  83%    1     2941      423    70557
localhost         Default     2502   0   5  95%  114       41      277      110
7 entries were displayed.
cluster1::>
The following example illustrates displaying historical statistics for management session activity on a specific node and for a specific location.
cluster1::> security session request-statistics show-by-location -node node2 -location localhost
localhost         Default     2524   0   5  95%  115       30      279      110
cluster1::>
