      system snmp show
Displays SNMP settings
Lists the current values of all the SNMP parameters.
The example below shows a typical command display.
cluster1::> system snmp show
  contact:
          private
          NB
  authtrap:
          1
  init:
          1
  traphosts:
          xxx.example.com(xxx.example.com)(192.168.xxx.xxx)
  community:
