      volume efficiency promote
Add a volume to the preferred set of volumes for efficiency processing
Use the volume efficiency promote command to promote a volume from deprioritized state back to auto state.
- -vserver <vserver name>- Vserver Name (privilege: advanced)
This specifies the Vserver on which the volume is located.
- { -volume <volume name>- Volume Name (privilege: advanced)
This specifies the name of the volume on which auto scheduling needs to be restarted.
- | -path </vol/volume>- Volume Path (privilege: advanced) }
This specifies the volume path on which auto scheduling needs to be restarted.
The following examples promote a volume from deprioritized state back to auto state.
cluster1::> volume efficiency promote -vserver vs1 -volume vol1
 PDFs
PDFs
