cluster peer offer modify
Modify an outstanding offer to authenticate with a peer cluster
The cluster peer offer modify command modifies the outstanding offer to authenticate with a potentially peered cluster. Every authentication offer has an expiration time, after which the offer will no longer be honored. This command is used to change that expiration time. To cancel the offer outright, use the cluster peer offer cancel command instead.
-cluster <text>- Peer Cluster Name-
Use this parameter to specify the offer to be modified by indicating the name of the cluster to which it has been extended.
[-offer-expiration {MM/DD/YYYY HH:MM:SS | {1..7}days | {1..168}hours}]- Authentication Offer Expiration Time-
Use this parameter to specify the new expiration time for the offer.
[-initial-allowed-vserver-peers <Vserver Name>,…]- Vservers Initially Allowed for Peering-
Use this optional parameter to specify the list of Vservers for which reciprocal Vserver peering with peer cluster should be enabled.
This example modifies the expiration time for the authentication offer to push it out by an hour.
cluster1::> cluster peer offer show
Peer Cluster Name Authentication Creation Expiration
cluster2 absent_but_offer
7/23/2013 14:45:47 7/23/2013 15:45:47
cluster1::> cluster peer offer modify -cluster cluster2 -offer-expiration "7/23/2013 16:45:47"
7/23/2013 14:45:47 7/23/2013 16:45:47
