vserver fcp interface show
Display configuration information for an FCP interface
This command displays FCP logical interface information. If you do not specify a Vserver, the command displays all of the FCP data interfaces of a cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter with other options to display information about FCP logical interfaces scoped to the specified Vserver.
[-lif <lif-name>] - Logical Interface
Use this parameter to display FCP logical interfaces that match the names of logical interfaces that you specify. You can provide a partial logical interface name, and press tab to complete the name or the closest match.
[-wwpn <text>] - WWPN
Use this parameter to display FCP logical interfaces that match the World Wide Port Name (WWPN) that you specify.
[-wwnn <text>] - WWNN
Use this parameter to display FCP logical interfaces that match the World Wide Node Name (WWNN) that you specify.
[-status-admin {up|down}] - Administrative Status
Specifies the configured status of the FCP logical interface. If you set this parameter to up the command displays all FCP logical interfaces with the administrative status of up If you set this parameter to down the command displays all the FCP logical interfaces with the administrative status of down .
[-status-oper {up|down}] - Operational Status
Specifies the current status of the FCP logical interface. If you set this parameter to up the command displays all the FCP logical interfaces with the operational status of up If you set this parameter to down the command displays all the FCP logical interfaces with the operational status of down .
[-status-extended <text>] - Extended Status
Use this parameter to display more detailed information on the status of the FCP logical interface that you specify.
[-port-address <Hex Integer>] - Host Port Address
Use this parameter to display FCP logical interfaces that match the host port address that you specify.
[-curr-node <nodename>] - Current Node
Use this parameter to display FCP logical interfaces that are on the node that you specify.
[-curr-port {<netport>|<ifgrp>}] - Current Port
Use this parameter to display FCP logical interfaces that are on the port that you specify.
[-is-home {true|false}] - Is Home
Specifies whether the node hosting the FCP interface is the initially configured node. If you use this command without using this parameter, it is set to true, and the command displays all FCP interfaces that are on the initially configured node.
[-relative-port-id <integer>] - Relative Port ID
Use this parameter to display FCP logical interfaces that match the relative target port ID that you specify. The system assigns each LIF and target portal group a relative target port ID that is Vserver unique. You cannot change this ID.
cluster1::> vserver fcp interface show
     Logical    Status                      Current       Current Is
Vserver    Interface  Admin/Oper WWPN             Node          Port    Home
vs1        vs1.fcp    up/down    2f:a2:00:a0:98:0b:56:13
                                                  node1         0c      true
Displays all FCP interface information.
