cluster ring show
Display cluster node member’s replication rings
The cluster ring show command displays a cluster’s ring-replication status. Support personnel might ask you to run this command to assist with troubleshooting.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the rings that match this parameter value.
[-unitname {mgmt|vldb|vifmgr|bcomd|crs|availd}]<
