system controller config show
Display System Configuration Information
The system controller config show command displays system configuration information for the devices present in the controller. To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the nodes that match this parameter value.
[-device <text>]- Device-
Selects the configuration information that matches the specified device.
[-slot <integer>]- Slot Number-
Selects the configuration information that matches the specified slot.
[-subslot <integer>]- Subslot Number-
Selects the configuration information that matches the specified subslot.
[-info <text>]- Device Info-
Selects the configuration information that matches the specified device information.
The following example displays configuration information for slot 1 of the controller:
cluster1::> system controller config show -slot 1
Node: node1
Sub- Device/
Slot slot Information
1 - NVRAM10 HSL
Device Name: Interconnect HBA: Generic OFED Provider
Port Name: ib1a
Default GID: fe80:0000:0000:0000:0000:0000:0000:0104
Base LID: 0x104
Active MTU: 8192
Data Rate: 0 Gb/s (8X)
Link State: DOWN
QSFP Vendor: Amphenol
QSFP Part Number: 112-00436+A0
QSFP Type: Passive Copper 1m ID:00
QSFP Serial Number: APF16130066875
QSFP Serial Number: APF16130066857
cluster1::>
