ONTAP commands
volume inode-upgrade resume
Resume suspended inode upgrade
The volume inode-upgrade resume command resumes suspended inode upgrade process. The inode upgrade process may be suspended earlier due to performance reasons.
-vserver <vserver name> - VServer Name (privilege: advanced)
This specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name (privilege: advanced)
This specifies the volume for which the inode upgrade process is to be resumed.
The following example resumes a volume upgrade process.
cluster1::> volume inode-upgrade resume -vserver vs0 -volume vol1
