job schedule delete
PDF of this doc site
Creating your file...
Delete a schedule
The job schedule delete
command deletes a schedule. Use the job schedule show command to display all current schedules.
You cannot delete any schedules that are in use by jobs. Use the job schedule show-jobs command to display jobs by schedule.
You cannot delete any schedules that are referenced by:
Volume Snapshot copy policy entries
SnapMirror entries
SIS policy entries
configuration backup settings
You must remove all references to a schedule before you can delete it. If you attempt to delete a schedule that is referenced, an error message will list which entries reference the schedule you want to delete. Use the show
command for each of the items listed by the error message to display which entries reference the schedule. You may need to use the -instance
parameter to display more detail.
[-cluster <Cluster name>]
- Cluster-
This parameter specifies the name of the cluster on which you want to delete a schedule. By default, the schedule is deleted from the local cluster. In a MetroCluster configuration, the partner cluster can be specified if the local cluster is in switchover state.
-name <text>
- Schedule Name-
Use this parameter with the name of an existing schedule to specify the schedule you want to delete.
The following example deletes a schedule named overnightbackup:
cluster1::> job schedule delete -name overnightbackup
