job schedule show
Display a list of available schedules
The job schedule show
command displays information about schedules.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-cluster <Cluster name>]
- Cluster-
Selects the schedules that match this parameter value.
[-name <text>]
- Schedule Name-
[-type {cron|interval|builtin}]
- Schedule Type-
[-description <text>]
- Description-
The following example displays information about all schedules:
cluster1::> job schedule show Cluster Name Type Description ------------- ----------- --------- ------------------------------------------- cluster1 5min cron @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55 daily cron @0:10 hourly cron @:05 monthly cron 1@0:20 weekly cron Sun@0:15
