ONTAP commands
vserver nvme namespace modify
Modify NVMe namespace
The vserver nvme namespace modify command modifies NVMe namespace attributes.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-path <path> - Namespace Path
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are /vol/vol1/ns1 and /vol/vol1/qtree1/ns1 .
[-comment <text>] - Comment
Contains a textual description of the NVMe namespace.
cluster1::*> vserver nvme namespace modify -path /vol/nsvol/ns1 -vserver vs_1 -comment "Comment text."
Modifies the value of the comment field for the NVMe namespace at path /vol/nsvol/ns1 on Vserver vs_1 .
