network bgp defaults modify
Modify BGP defaults
The network bgp defaults modify command modifies the global defaults for border gateway protocol (BGP) configurations.
[-asn <integer>]- Autonomous System Number-
This parameter specifies the autonomous system number (ASN). The ASN attribute is a non-negative 16-bit integer. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use", or the AS number assigned to the operator's organization. The default ASN is 65501.
[-hold-time <integer>]- Hold Time-
This parameter specifies the hold time in seconds. The default value is 180.
cluster1::> network bgp defaults modify -asn 20
