ONTAP commands
vserver vscan on-demand-task run
Run an On-Demand task
The vserver vscan on-demand-task run command start virus scanning immediately for an On-Demand task.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver on which you want to start start virus scanning.
-task-name <text> - Task Name
This parameter specifies the name of the On-Demand task that you want to start virus scanning.
The following example starts virus scanning an On-Demand task:
cluster1::> vserver vscan on-demand-task run -vserver vs1 -task-name t1
[Job 161]: Vscan On-Demand job is queued. Use the "job show -id 161" command to view the status.
