ONTAP 9.5 commands
snaplock event-retention abort
Abort an Event Based Retention policy operation.
The snaplock event-retention abort is used to abort an ongoing Event Based Retention (EBR) operation. This command only aborts the operations that have not yet completed. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
Specifies the vserver on which the EBR operation is running.
-operation-id <integer> - Operation ID
Specifies the operation ID of the EBR operation that needs to be aborted.
The following example aborts an ongoing EBR operation with operation-id 16842754 :
vs1::> snaplock event-retention abort -operation-id 16842754
            vs1::>
