volume file retention show
Display retention time of a file protected by SnapLock.
The volume file retention show
command displays the retention time of a file protected by SnapLock given -vserver
and -file
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
Specifies the name of the Vserver which has the file.
[-file </vol/<volume name>/<file path>>]
- File path-
Specifies the absolute path of the file. The value begins with /vol/<volumename>.
[-retention-time <integer>]
- Retention Time of the File-
If this paramater is specified, the command returns the retention time of the file protected by SnapLock if its retention time in seconds since 1 January 1970 00:00:00 matches the specified value.
[-formatted-retention-time <text>]
- Formatted Retention Period-
If this paramater is specified, the command returns the retention time of the file protected by SnapLock if its expiry date matches the specified value. The expiry date format is <day> <month> <day of month> <hour>:<min>:<sec><year> in GMT timezone taking care of wraparound. A value of
infinite
indicates that this file has infinite retention time. A value ofindefinite
indicates that this file has indefinite retention time. [-is-wraparound {true|false}]
- Is Retention Time Wraparound-
If this paramater is specified, the command returns the retention time of the file protected by SnapLock if it has a matching
-is-wraparound
value. The value istrue
if the date represented in retention time is in wraparound format. The wraparound format indicates that dates after 19 January 2038 are mapped from 1 January 1970 through 31 December 2002 to 19 January 2038 through 19 January 2071.
The following example displays the retention time of the file /vol/nfs_sle/f12
cluster1::> volume file retention show -vserver vs0 -file /vol/nfs_sle/f12 Vserver : vs0 Path : /vol/nfs_sle/f12 Retention Time (Secs from Epoch) : 1439111404 Formatted Retention Time : Sun Aug 9 09:10:04 GMT 2015 Is Retention Time Wraparound : false
