lun mapping show-initiator
Show the LUN mappings to a specific initiator
The lun mapping show-initiator command lists the LUNs which are mapped to an initiator group which contains a specific initiator.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
Selects the LUN mappings for the vserver that you specify.
-initiator <text>- Initiator Name (privilege: advanced)-
Selects the LUN mappings for the initiator that you specify.
[-lun-id <integer>]- Logical Unit Number (privilege: advanced)-
Selects the LUN mappings with a LUN ID that you specify.
[-igroup <text>]- Igroup Name (privilege: advanced)-
Selects the LUN mappings for the initiator group that you specify.
[-path <path>]- LUN Path (privilege: advanced)-
Selects the LUN mappings for the LUN path that you specify.
[-node <nodename>]- LUN Node (privilege: advanced)-
Selects the LUN mappings for the LUNs which are being hosted on the node that you specify.
[-reporting-nodes <nodename>,…]- Reporting Nodes (privilege: advanced)-
Selects the LUN mappings for the LUNs which have reporting nodes that you specify.
[-vserver-uuid <UUID>]- Vserver UUID (privilege: advanced)-
Selects the LUN mappings for the Vserver UUID that you specify.
[-igroup-uuid <UUID>]- Igroup UUID (privilege: advanced)-
Selects the LUN mappings for the initiator group UUID that you specify.
[-lun-uuid <UUID>]- LUN UUID (privilege: advanced)-
Selects the LUN mappings for the LUN UUID that you specify.
The following example displays the LUN mappings for initiator 20:10:0a:50:00:01:01:01 in Vserver vs1 .
cluster1::> lun mapping show-initiator -vserver vs1 -initiator 20:10:0a:50:00:01:01:01
Vserver Initiator LUN ID Path IGroup
vs1 20:10:0a:50:00:01:01:01
0 /vol/igroup_1_1_vol/lun1 igroup_1
2 /vol/igroup_1_1_vol/lun3 igroup_1
3 /vol/igroup_1_2_vol/lun1 igroup_1
5 /vol/igroup_1_2_vol/lun3 igroup_1
6 /vol/igroup_1_3_vol/lun1 igroup_1
8 /vol/igroup_1_3_vol/lun3 igroup_1
9 /vol/igroup_1_4_vol/lun1 igroup_1
11 /vol/igroup_1_4_vol/lun3 igroup_1
12 /vol/igroup_2_1_vol/lun1 igroup_2
14 /vol/igroup_2_1_vol/lun3 igroup_2
15 /vol/igroup_2_2_vol/lun1 igroup_2
17 /vol/igroup_2_2_vol/lun3 igroup_2
18 /vol/igroup_2_3_vol/lun1 igroup_2
20 /vol/igroup_2_3_vol/lun3 igroup_2
21 /vol/igroup_2_4_vol/lun1 igroup_2
23 /vol/igroup_2_4_vol/lun3 igroup_2
16 entries were displayed.
