ONTAP commands
event filter rule delete
Delete a rule for an event filter
The event filter rule delete command deletes a rule from an event filter. The position of all the rules following the deleted rule is updated to maintain a contiguous sequence. Use event filter show command to view the filters and the rules associated with them.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter from which you want to delete the rule. Rules cannot be deleted from system-defined filters.
-position <integer> - Rule Position
Use this mandatory parameter to specify the position of the rule to delete from the filter. It should be in the range (1..n-1), where 'n' is the position of the last rule, which is an implicit rule.
The following example deletes a rule at position 2 from an existing event filter "emer-and-wafl":
cluster1::> event filter show
Filter Name Rule     Rule      Message Name           SNMP Trap Type  Severity
      Position Type
default-trap-events
      1        include   *                      *               EMERGENCY, ALERT
      2        include   *                      Standard, Built-in
      3        exclude   *                      *               *
emer-and-wafl
      1        include   wafl.scan.*            *               ALERT
      2        include   wafl.*                 *               EMERGENCY
      3        include   *                      Standard        *
      4        exclude   *                      *               *
important-events
      2        include   callhome.*             *               ERROR
      3        exclude   *                      *               *
no-info-debug-events
      1        include   *                      *               EMERGENCY, ALERT, ERROR, NOTICE
      2        exclude   *                      *               *
12 entries were displayed.
cluster1::> event filter rule delete -filter-name emer-and-wafl -position 2
      Position Type
default-trap-events
      3        exclude   *                      *               *
emer-and-wafl
      2        include   *                      Standard        *
      3        exclude   *                      *               *
important-events
      3        exclude   *                      *               *
      2        exclude   *                      *               *
11 entries were displayed.
Looking for answers?
Try Doc, our Gen AI Assistant.
