snaplock event-retention policy show
Show SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy show command is used to show Event Based Retention (EBR) policies for a Vserver. A policy consists of a policy-name and a retention-period . The command output depends on the parameter or parameters specified. If no parameters are specified, all policies for all vservers will be displayed. If one or more parameters are specified, only those entries matching the specified values will be displayed. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter is specified, the command displays all EBR policies that match the specified Vserver.
 [-name <text>]- Policy Name-
name. [-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Event Retention Period-
retention-period.
The following example displays all event-retention policies for vserver "vs1":
vs1::> snaplock event-retention policy show
            Vserver           Name                Retention Period
            vs1               p1                  10 years
            vs1               p2                  5 years
