vserver cifs session file show
Display opened CIFS files
The vserver cifs session file show command displays information about all open CIFS files. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all open CIFS files:
Node name
Vserver name
CIFS connection ID
CIFS session ID
CIFS file ID
CIFS file type
CIFS file open mode
CIFS file hosting volume
CIFS share name
CIFS file path
Continuously available protection level
You can specify additional parameters to display only information that matches those parameters. For example, to display information only about CIFS files opened on connection ID 2012, run the command with the `-connection-id parameter set to ` 2012.
[-fields <fieldname>,…] -
If you specify this parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify this parameter, the command displays detailed information about matching open CIFS files.
[-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information about the open CIFS files on the specified node.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information about open CIFS files on the specified CIFS-enabled Vserver.
[-file-id <integer>]- File ID-
If you specify this parameter, the command displays information about the open CIFS file that match the specified file ID.
[-connection-id <integer>]- Connection ID-
If you specify this parameter, the command displays information about open CIFS files that are opened on the specified connection ID.
[-session-id <integer>]- Session ID-
If you specify this parameter, the command displays information about the CIFS file that are opened on the specified session ID.
[-connection-count <integer>]- Connection Count-
If you specify this parameter, the command displays information about CIFS files opened through a session that have the specified number of CIFS connections.
[-file-type <CIFS File Type>]- File Type-
If you specify this parameter, the command displays information about opened CIFS files that are of the specified file type. The file type can be any of these: Regular, Symlink, Stream, or Directory.
[-open-mode <CIFS Open Mode>]- Open Mode-
If you specify this parameter, the command displays information about CIFS files that are opened with the specified mode. The open mode can include one or more of the following:
R - This property specifies that the file is opened for read.
W - This property specifies that the file is opened for write.
D - This property specifies that the file is opened for delete.
The open mode can have multiple values specified as a list with no commas.
[-hosting-aggregate <aggregate name>]- Aggregate Hosting File-
If you specify this parameter, the command displays information about open CIFS files that reside on the specified aggregate.
[-hosting-volume <volume name>]- Volume Hosting File-
If you specify this parameter, the command displays information about open CIFS files that reside on the specified volume.
[-share <Share>]- CIFS Share-
If you specify this parameter, the command displays information about CIFS files that are opened over the specified CIFS share.
[-path <text>]- Path from CIFS Share-
If you specify this parameter, the command displays information about open CIFS files that match the specified CIFS file path.
[-share-mode <CIFS Open Mode>]- Share Mode-
If you specify this parameter, the command displays information about open CIFS files that are opened with the specified share mode. The share mode can include one or more of the following:
R - This property specifies that the file is shared for read.
W - This property specifies that the file is shared for write.
D - This property specifies that the file is shared for delete.
The share mode can have multiple values specified as a list with no commas.
[-range-locks <integer>]- Range Locks-
If you specify this parameter, the command displays information about open CIFS files that have the specified number of range locks.
[-continuously-available <CIFS Open File Protection>]- Continuously Available-
If you specify this parameter, the command displays information about open CIFS files with or without continuously available protection. The open files are "continuously available" if they are opened from an SMB 3 client through a share with the "continuously_available" property set. These open files are capable of non-disruptively recovering from takeover and giveback as well as general aggregate relocation between partners in a high-availability relationship. Streams opened through a continuously available share are permitted, but are not currently made continuously available. Directories may be opened through a continuously available share, but, by design, will not appear continuously available as clients do not open them that way. These protection levels are applicable to the files on read/write volumes residing on storage failover aggregates.
The continuously available status can be one of the following:
No - The open file is not continuously available.
Yes - The open file is continuously available.
[-reconnected <text>]- Reconnected-
If you specify this parameter, the command displays information about open CIFS files that have the specified reconnected state. The reconnected state can be one of the following:
No - The open file is not reconnected.
Yes - The open file is reconnected.
The following example displays information about all open CIFS files:
cluster1::> vserver cifs session file show Node: node1 Vserver: vs1 Connection: 2192 Session: 1 Connection Count: 4 File File Open Hosting Continuously ID Type Mode Volume Share Available ------- --------- ---- --------------- --------------------- ------------ 7 Regular rw rootvs1 rootca Yes Path: \win8b8.txt
The following example displays information about a CIFS file with file-id 7.
cluster1::> vserver cifs session file show -file-id 7 -instance
Node: node1
Vserver: vs1
File ID: 7
Connection ID: 2192
Session ID: 1
Connection count: 4
File Type: Regular
Open Mode: rw
Aggregate Hosting File: aggr1
Volume Hosting File: rootvs1
CIFS Share: rootca
Path from CIFS Share: \win8b8.txt
Share Mode: rd
Range Locks: 0
Continuously Available: Yes
Reconnected: No
