      volume efficiency check
Scrub efficiency metadata of a volume
This command verifies and updates the fingerprint database for the specified volume. This command is not supported on FlexGroups or Infinite Volumes that are managed by storage services.
- -vserver <vserver name>- Vserver Name (privilege: advanced)
Specifies the Vserver on which the volume is located.
- { -volume <volume name>- Volume Name (privilege: advanced)
Specifies the volume on which the verify operation needs to be started.
- | -path </vol/volume>- Volume Path (privilege: advanced) }
Specifies the volume path on which the verify operation needs to be started.
- [-d, -delete-checkpoint {true|false}]- Delete Checkpoint (privilege: advanced)
Deletes existing checkpoint.
The following example runs volume efficiency check with delete checkpoint option turned on.
cluster1::> volume efficiency check -vserver vs1 -volume vol1 -delete-checkpoint true
 PDFs
PDFs
