vserver cifs show
PDF of this doc site
Creating your file...
Display CIFS servers
The vserver cifs show
command displays information about CIFS servers. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
Vserver name
CIFS server NetBIOS name
Domain or workgroup name
Authentication style
You can specify the -fields
parameter to specify which fields of information to display about CIFS servers. In addition to the fields above, you can display the following fields:
Default site
Fully-qualified domain name
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about CIFS servers that are in the CIFS domain named RUBY, run the command with the -domain-
