ONTAP commands
network tuning tcp modify
Modify TCP tuning options
This commands sets TCP tuning options on the node.
-node {<nodename>|local} - Node
Indicates on which node the TCP tuning options will be modified.
[-is-path-mtu-discovery-enabled {true|false}] - Path MTU discovery enabled
Enables path MTU discovery feature.
[-is-rfc3465-enabled {true|false}] - RFC3465 enabled
Enables the rfc3465 feature.
[-max-cwnd-increment <integer>] - Maximum congestion window segments incrementation
Sets the maximum congestion window increment segements during slow start.
[-is-rfc3390-enabled {true|false}] - RFC3390 enabled
Enables the rfc3390 feature.
[-is-sack-enabled {true|false}] - SACK supoort enabled
Enables the selective ACK feature.
cluster1::> network tuning tcp modify -node node1 -is-path-mtu-discovery-enabled false
