      network tuning tcp modify
Modify TCP tuning options
This commands sets TCP tuning options on the node.
- -node {<nodename>|local}- Node
Indicates on which node the TCP tuning options will be modified.
- [-is-path-mtu-discovery-enabled {true|false}]- Path MTU discovery enabled
Enables path MTU discovery feature.
- [-is-rfc3465-enabled {true|false}]- RFC3465 enabled
Enables the rfc3465 feature.
- [-max-cwnd-increment <integer>]- Maximum congestion window segments incrementation
Sets the maximum congestion window increment segements during slow start.
- [-is-rfc3390-enabled {true|false}]- RFC3390 enabled
Enables the rfc3390 feature.
- [-is-sack-enabled {true|false}]- SACK supoort enabled
Enables the selective ACK feature.
cluster1::> network tuning tcp modify -node node1 -is-path-mtu-discovery-enabled false
 PDFs
PDFs
