volume flexcache origin cleanup-cache-relationship
Cleanup the cache relationship
The volume flexcache origin cleanup-cache-relationship command is used to cleanup the cache relationship on the origin of a FlexCache cluster.
This command only needs to be run if volume flexcache delete fails on the FlexCache cluster and prompts you to run this command. |
-origin-vserver <vserver name>- Origin Vserver (privilege: advanced)-
This specifies the name of the Vserver hosting the origin of a FlexCache volume.
-origin-volume <volume name>- Origin Volume (privilege: advanced)-
This specifies the name of the origin of a FlexCache volume.
-cache-vserver <vserver name>- Cache Vserver (privilege: advanced)-
This specifies the name of the Vserver hosting the FlexCache volume.
-cache-volume <volume name>- Cache Volume (privilege: advanced)-
This specifies the name of the FlexCache volume.
[-force-retry <true>]- Force Origin Cleanup Retry (privilege: advanced)-
This specifies whether the origin cleanup operation can be retried if it has previously failed. The default setting is
false.When the last FlexCache relationship is deleted, the origin cleanup operation needs to remove metadata from the filesystem. This can take a long time, and it's possible the operation will take too long and fail. In that case, the operation can be retried by running the cleanup command again and setting froce-retryto true.
The following example cleans up the FlexCache relationship for the specified FlexCache and origin of a FlexCache volume:
cluster1::> flexcache origin cleanup-cache-relationship -origin-volume origin1 -origin-vserver vs34 -cache-vserver vs56 -cache-volume fc1
(volume flexcache origin cleanup-cache-relationship)
Warning: The cache configuration will be deleted for Origin-Vserver: vs34,
Origin-Volume: origin1, Cache-Vserver: vs56, Cache-Volume:
fc1.
Do you want to continue? {y|n}: y
