system node virtual-machine hypervisor show-credentials
Display hypervisor IP address and its credentials
The system node virtual-machine hypervisor show-credentials command displays the current vSphere authentication information (except the password). This consists of the vSphere server and username. The vSphere password is not displayed for security reasons. vSphere authentication information is required to use (system node virtual-machine hypervisor show-node <node> , system node virtual-machine instance show-system-disks-node <node>  and storage disk show -virtual-machine-disk-info-node <node> ) to be able to gather information about the physical host machine. It also attempts to verify the current vSphere authentication information with the vSphere host. If the check succeeds and the credentials are correct, the command displays the following information. If you want to see details about a single node, use the -node parameter.
Node
Hypervisor name or IP Address
vSphere Username
Credentials Correct?:
true
If the check fails or credentials are incorrect, the command displays an additional Error .
Node
vSphere Username
false -
Error:
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This optional parameter represents the name of the Data ONTAP node running in a virtual machine for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
 [-server <text>]- Hypervisor IP Address or Hostname-
Use this parameter to only display the Data ONTAP nodes in the cluster whose vSphere server matches this value.
 [-username <text>]- Hypervisor Username-
Use this parameter to only display the Data ONTAP nodes in the cluster whose vSphere username matches this value.
 [-are-credentials-correct {true|false}]- Credentials Correct?-
Get a list of Data ONTAP nodes running with either incorrect (false) or correct (true) vSphere credentials.
 [-error <text>]- Error-
Get a list of nodes with the specified error. This parameter is most useful when entered with wildcards.
The following example shows the vSphere server and vSphere username. It also displays whether the server address or its credentials are correct and displays an error if they are not.
cluster1::> system node virtual-machine hypervisor show-credentials
                 Node: node1
Hypervisor IP Address: 192.168.0.1
     vSphere Username: administrator
 Credentials Correct?: true
Node: node2
 Credentials Correct?: false
Error: [13166] could not find IP addr for host.
Correct the vSphere credentials with the
"system node virtual-machine hypervisor modify-credentials -node" command.
2 entries were displayed.
