      network tuning icmp show
Show ICMP tuning options
This command displays the current state of the ICMP tuning options for the given node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays all ICMP tuning options.
 [-node {<nodename>|local}]- Node-
Specifies the node for which the ICMP tuning options are displayed.
 [-is-drop-redirect-enabled {true|false}]- Drop redirect ICMP-
Displays all entries that match the "is-drop-redirect-enabled" value.
 [-tx-icmp-limit <integer>]- Maximum number of ICMP packets sent per second-
Displays all entries that match the "tx-icmp-limit" value.
 [-redirect-timeout <integer>]- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-timeout" value.
cluster1::> network tuning icmp show
Drop Redirect Maximum ICMP      Redirect Timeout
Node      ICMP          Sends per Second  in Seconds
node1
          true          100               300
