network tuning icmp show
PDF of this doc site
Creating your file...
Your file is ready
Show ICMP tuning options
This command displays the current state of the ICMP tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all ICMP tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the ICMP tuning options are displayed.
[-is-drop-redirect-enabled {true|false}]
- Drop redirect ICMP-
Displays all entries that match the "is-drop-redirect-enabled" value.
[-tx-icmp-limit <integer>]
- Maximum number of ICMP packets sent per second-
Displays all entries that match the "tx-icmp-limit" value.
[-redirect-timeout <integer>]
- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-timeout" value.
cluster1::> network tuning icmp show Drop Redirect Maximum ICMP Redirect Timeout Node ICMP Sends per Second in Seconds --------- ------------- ---------------- ---------------- node1 true 100 300
