vserver security trace trace-result show
Display security trace results
The vserver security trace trace-result show command displays the list of security trace event records stored on the cluster. These records are generated in response to security trace filters that are created using the vserver security trace filter create command. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all the security trace events generated since the filter was enabled:
Vserver name
Cluster node name
Security trace filter index number
User name
Security style
Path
Reason
You can specify additional parameters to display only information that match those parameters. For example, to display information about events that occurred for the user "guest", run the command with `-user-name` parameter set to ``_guest_`` .
[-fields <fieldname>,…] -
If you specify this parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify this parameter, the command displays detailed information about all security trace events.
[-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information only about security trace events on the specified node.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about security trace events on the specified Vserver.
[-seqnum <integer>]- Sequence Number-
If you specify this parameter, the command displays information only about the security trace events with this sequence number.
[-keytime <Date>]- Time-
If you specify this parameter, the command displays information only about security trace events that occurred at the specified time.
[-index <integer>]- Index of the Filter-
If you specify this parameter, the command displays information only about security trace events that occurred as a result of the filter corresponding to the specified filter index number.
[-client-ip <IP Address>]- Client IP Address-
If you specify this parameter, the command displays information only about security trace events that occurred as a result of file access from the specified client IP address.
[-path <TextNoCase>]- Path of the File Being Accessed-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file accesses to the specified path.
[-win-user <TextNoCase>]- Windows User Name-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file access by the specified Windows user.
[-security-style <security style>]- Effective Security Style On File-
If you specify this parameter, the command displays information only about the security trace events that occurred on file systems with the specified security style. The allowed values for security style are the following:
SECURITY_NONE - Security not Set
SECURITY_UNIX_MODEBITS - UNIX and UNIX permissions
SECURITY_UNIX_ACL - UNIX and NFSv4 ACL
SECURITY_UNIX_SD - UNIX and NT ACL
SECURITY_MIXED_MODEBITS - MIXED and UNIX permissions
SECURITY_MIXED_ACL - MIXED and NFSv4 ACL
SECURITY_MIXED_SD - MIXED and NT ACL
SECURITY_NTFS_MODEBITS - NTFS and UNIX permissions
SECURITY_NTFS_ACL - NTFS and NT ACL
SECURITY_NTFS_SD - NTFS and NT ACL
SECURITY_UNIX - UNIX
SECURITY_MIXED - MIXED
SECURITY_NTFS - NTFS
SECURITY_MODEBITS - UNIX permissions
SECURITY_ACL - ACL
SECURITY_SD - SD
[-result <TextNoCase>]- Result of Security Checks-
If you specify this parameter, the command displays information about the security trace events that have the specified result. Access to a file or a directory can be 'allowed' or 'denied'. Output from this command displays the result as a combination of the reason for allowing or denying access, the location where access is either allowed or denied, and the access right for which the file operation is allowed or denied.
The following are the reasons why an access can be allowed:
* Access is allowed because the operation is trusted and no security is configured
* Access is allowed because the user has UNIX root privileges
* Access is allowed because the user has UNIX owner privileges
* Access is allowed because UNIX implicit permission grants requested access
* Access is allowed because the CIFS user is owner
* Access is allowed because the user has take ownership privilege
* Access is allowed because there is no CIFS ACL
* Access is allowed because CIFS implicit permission grants requested access
* Access is allowed because the security descriptor is corrupted and the user is a member of the Administrators group
* Access is allowed because the ACL is corrupted and the user is a member of the Administrators group
* Access is allowed because the user has UNIX permissions
* Access is allowed because explicit ACE grants requested access
* Access is allowed because the user has audit privileges
* Access is allowed because the user has superuser credentials
* Access is allowed because inherited ACE grants requested access
* Access is allowed because storage-level access guard (SLAG) grants requested access
* Access is allowed because no central access policies applied
* Access is allowed because no central access policies could be applied from the corrupt SACL
* Access is allowed because matching central access policy could not be located
* Access is allowed because no central access rules apply to the object
* Access is allowed because skipped one or more corrupt central access rules
* Access is allowed because all evaluated central access rules grant access+
The following are the reasons why an access can be denied:+
Access is denied by UNIX permissions
Access is denied by an explicit ACE
Access is denied. The requested permissions are not granted by the ACE
Access is denied. The security descriptor is corrupted
Access is denied. The ACL is corrupted
Access is denied. The sticky bit is set on the parent directory and the user is not the owner of file or parent directory
Access is denied. The owner can be changed only by root
Access is denied. The UNIX permissions/uid/gid/NFSv4 ACL can be changed only by owner or root
Access is denied. The GID can be set by owner to a member of its legal group list only if 'Owner can chown' is not set
Access is denied. The file or the directory has readonly bit set
Access is denied. There is no audit privilege
Access is denied. Enforce DOS bits blocks the access
Access is denied. Hidden attribute is set
Access is denied by an inherited ACE
Access is denied as the volume is readonly or directory is a snapshot
Access is denied. System attribute is not set in the request
Access is denied by the storage-level access guard (SLAG)
Access is denied, file is infected
Access is denied. Central access policy DB not ready
Access is denied. Central access rule is corrupt
Access is denied. Central access rule explicitly denied access
Access is denied. Matching central access policy not found
Access is denied because the user does not have UNIX root privileges
Access is denied because the UNIX user could not be mapped to a valid NT user
Access is denied because the UNIX permissions/uid/gid/NFSv4 ACL cannot be set in an NTFS qtree
The command or the location at which access was denied or allowed are as follows:
while traversing the directory.
while truncating the file.
while creating the directory.
while creating the file.
while checking parent's mode bits during delete.
while deleting the child.
while checking for child-delete access on the parent.
while reading security descriptor.
while accessing the link.
while creating or writing the file.
while opening existing file or directory.
while setting the attributes.
while reading the file.
while reading the directory.
while deleting the target during rename.
while deleting the child during rename.
while writing data in the parent during rename.
while adding a directory during rename.
while adding a file during rename.
while updating the target directory during rename.
while setting attributes.
while writing to the file.
while extending the coral file.
while creating the vdisk file.
while checking for stale locks before open.
while deleting a file or a directory.
while truncating a hidden file.
while truncating a file.
while truncating a system file.
while appending to a file or setting a file attribute.
while opening a file or directory for delete.
while checking for permission on parent directory during create.
while appending to the file.
while creating the device file.
while reading the user's access rights on an object.
The access rights for which the file operation is allowed or denied are as follows:
Append.
Delete.
Delete Child.
Execute.
Generic All.
Generic Execute.
Generic Read.
Generic Write.
Maximum Allowed.
Read.
Read Attributes.
Read Control.
Read EA.
System Security.
Synchronize.
Write.
Write Attributes.
Write DAC.
Write EA.
Write Owner.
None.
[-unix-user <TextNoCase>]- UNIX User Name-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file access by the specified UNIX user.
[-session-id <integer>]- CIFS Session ID-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file access by the specified CIFS session ID.
[-share-name <TextNoCase>]- Accessed CIFS Share Name-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file access by the specified CIFS share name.
[-protocol {cifs|nfs}]- Protocol-
If you specify this parameter, the command displays information only about the security trace events that occurred for the specified protocol.
[-volume-name <TextNoCase>]- Accessed Volume Name-
If you specify this parameter, the command displays information only about the security trace events that occurred as a result of file access by the specified volume name.
The following example displays information about security trace records:
cluster1::> vserver security trace trace-result show
Vserver: vserver_1
Node Index Filter Details Reason
cluster1-01 1 Security Style: MIXED Access is allowed because
and NT ACL CIFS implicit permission
file or directory.
Access is granted for:
"Read Attributes"
Protocol: cifs
Share: sh1
Path: /stk/bit
Win-User: cifs1\
administrator
Unix-User: root
Session-ID: 58455810
1 entries were displayed.
The following example displays information about security trace records for path /stk/bit/set:
cluster1::> vserver security trace trace-result show -path /stk/bit/set
Vserver: vserver_1
and UNIX permissions the user has UNIX root
privileges while opening
existing file or
directory.
Access is granted for: "Read"
Protocol: cifs
Share: sh1
Path: /stk/bit/set
Win-User: cifs1\
administrator
UNIX-User: root
Session-ID: 75435293758455810
cluster1-01 1 Security Style: MIXED Access is denied. The
and NT ACL requested permissions
ACE while checking for
the parent. Access is not
granted for: "Delete Child"
Protocol: cifs
Share: sh1
Path: /stk/bit/set
Win-User: cifs1\
administrator
UNIX-User: root
Session-ID: 75435293758455324
and NT ACL the CIFS user is owner.
explicit ACE while
Access is not granted for:
"Read Attributes"
Protocol: cifs
Share: sh1
Path: /stk/bit/set
Win-User: cifs1\
administrator
UNIX-User: root
3 entries were displayed.
The following example displays information about security trace records for the protocol nfs:
cluster1::> vserver security trace trace-result show -protocol nfs
Vserver: vserver_1
cluster1-01 2 Security Style: UNIX Access is allowed because the
permissions user has UNIX root privileges
Protocol: nfs
Volume: testvol_flex
Share: -
Path: /f1
Win-User: -
UNIX-User: root
Session-ID: -
Access is granted for: "Write"
Protocol: nfs
Share: -
Path: /f1
Win-User: -
UNIX-User: root
Session-ID: -
cluster1-01 3 Security Style: UNIX Access is denied by UNIX
permissions permissions while creating
the file. Access is not
granted for: "Synchronize",
"Read Control", "Read
Attributes", "Execute",
"Write"
Protocol: nfs
Share: -
Path: /d1/file
Win-User: -
UNIX-User: 1029
Session-ID: -
