storage tape show-media-changer
Display information about media changers
This storage tape show-media-changer command displays information about media changers attached to the cluster. By default, this command displays the following information about all media changers:
Device ID of media changer
Description of media changer
World Wide Node Name of media changer
World Wide Port Name of media changer
Serial number of media changer
Media changer errors
Node to which the media changer is attached
Initiator port which hosts the media changer
Alias name of media changer
Operational state of media changer
Functional status of media changer
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-device-id <text>]- Device ID-
Selects the media changer with the specified device ID.
 [-node {<nodename>|local}]- Node-
Displays detailed information about media changers on the specified node.
 [-description <text>]- Description-
Selects the media changers with the specified description.
 [-alias-name <text>]- Alias Name-
Selects the media changer with the specified alias name.
 [-wwnn <text>]- World Wide Node Name-
Selects the media changers with the specified World Wide Node Name.
 [-wwpn <text>]- World Wide Port Name-
>Selects the media changer with the specified World Wide Port Name.
 [-serial-number <text>]- Serial Number-
Selects the media changer with the specified serial number.
 [-device-if-type {unknown|fibre-channel|SAS|pSCSI}]- Device If Type-
Selects the media changers with the specified interface type.
 [-device-state {unknown|available|ready-write-enabled|ready-write-protected|offline|in-use|error|reserved-by-another-host|normal}]- Operational State of Device-
Selects the media changers with the specified operational state.
 [-error <text>]- Media Changer Error Description-
Selects the media changers with the specified error string.
 [-initiator <text>]- Initiator Port-
Selects the media changers with the specified initiator port.
The following example displays information about all media changers attached to the cluster:
cluster1::> storage tape show-media-changer
Media Changer: sw4:10.11L1
  Description: PX70-TL
         WWNN: 2:00a:000e11:10b919
         WWPN: 2:00b:000e11:10b919
Serial Number: 00FRU7800000_LL1
Errors: -
Paths:
Node                      Initiator  Alias    Device State              Status
cluster1-01               2b         mc0      in-use                    normal
Media Changer: sw4:12.4L1
  Description: NEO-TL
         WWNN: 2:001:000e11:10b919
         WWPN: 2:002:000e11:10b919
Serial Number: 00FRU7800000_LL0
Errors: -
Paths:
cluster1-01               5a         mc1      available                 normal
