ONTAP commands
job schedule interval delete
Delete an interval schedule
The job schedule interval delete command deletes an interval schedule. Use the job schedule interval show command to display all current interval schedules.
You cannot delete interval schedules that are currently being run. Use the job schedule show-jobs command to display jobs by schedule.
[-cluster <Cluster name>] - Cluster
This parameter specifies the name of the cluster on which you want to delete an interval schedule. By default, the schedule is deleted from the local cluster. In a MetroCluster configuration, the partner cluster can be specified if the local cluster is in switchover state.
-name <text> - Name
Use this parameter with the name of an existing interval schedule to specify the interval schedule you want to delete.
The following example deletes an interval schedule named rollingdaily:
cluster1::> job schedule interval delete -name rollingdaily
