cluster date show
PDF of this doc site
Creating your file...
Your file is ready
Display the current date and time for the nodes in the cluster
The cluster date show
command displays the time zone, date, and time settings for one or more nodes in the cluster. By default, the command displays date and time settings for all nodes in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-utc ]
Displays date and time information in Coordinated Universal Time (UTC).
[-utcdate ]
Displays date and time information in UTC.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields.
