vserver iscsi interface modify
Modify network interfaces used for iSCSI connectivity
The vserver iscsi interface modify
command modifies the iSCSI specific configuration for an iSCSI LIF.
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver.
-lif <lif-name>
- Logical Interface-
Use this parameter to specify the logical interface on a Vserver that you want to modify.
[-sendtargets-fqdn <text>]
- iSCSI Discovery SendTargets FQDN-
Use this parameter to specify the Fully Qualified Domain Name (FQDN) to return during an iSCSI Discovery SendTargets operation. To clear the FQDN, set this parameter to "". If unset, the IP address of the LIF is used in iSCSI SendTargets discovery. + This is not part of iSNS and will not affect the iSNS configuration.
The following example modifies the sendtargets-fqdn of the iSCSI LIF vs1_iscsi1 for Vserver vs1 to myhost.example.com.
cluster1::> vserver iscsi interface modify -vserver vs1 -lif vs1_iscsi1 -sendtargets_fqdn myhost.example.com
