event mailhistory delete
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Delete an e-mail history record
This command has been deprecated. It may be removed from a future major release of Data ONTAP. Instead, use the "event notification history" command set. |
The event mailhistory delete
command deletes a record from the e-mail history.
To delete a record, you must know which node contains the record, and the record's sequence number. Use the event mailhistory show command to view this information.
-node {<nodename>|local}
- Node-
Use this parameter to specify the name of the node that contains the e-mail history record to delete.
-seqnum <Sequence Number>
- Sequence Number-
Use this parameter to specify the sequence number of the e-mail history record to delete.
The following example deletes all mail-history records on node1:
cluster1::> event mailhistory delete -node node1 -seqnum *
