event mailhistory show
PDF of this doc site
Creating your file...
(DEPRECATED)-Display a list of e-mail history records
This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event notification history" command set. |
The event mailhistory show
command displays a list of the event notifications that have been e-mailed. The command output depends on the parameters you specify with the command. By default, the command displays basic information about all notification e-mails that were sent.
To display detailed information about a specific mail-history record, run the command with the -seqnum
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the mail-history records that match this parameter value.
[-seqnum <Sequence Number>]
- Sequence Number-
[-message-name <Message Name>]
- Message Name-
[-address <mail address>,…]
- Mail Address-
[-time <MM/DD/YYYY HH:MM:SS>]
- Transmission Time-
[-message <text>]
- Alert Message-
Selects the mail-history records that match this parameter value (text pattern).
[-previous-time <MM/DD/YYYY HH:MM:SS>]
- Previous Transmission Time-
[-num-drops-since-previous <integer>]
- Number of Drops Since Previous Transmission-
Selects the mail-history records that match this parameter value (number of event drops since last transmission).
The following example displays detailed information about the mail-history record with the sequence number 20520:
cluster1::> event mailhistory show -seqnum 20520 Sequence Number: 20520 Message Name: wafl.vol.full Address: admin@example.com Time: 10/1/2008 14:06:24 Node: node3 Previous Time: 5/31/2007 00:33:22 # Drops Since Prev: 0 Mail Message: wafl.vol.full: file system on volume vol0@vserver:28558fe3-2462-11da-85ab -000423bacd20 is full
