ONTAP commands
event mailhistory delete
(DEPRECATED)-Delete an e-mail history record
Note This command has been deprecated. It may be removed from a future major release of Data ONTAP. Instead, use the "event notification history" command set.
The event mailhistory delete command deletes a record from the e-mail history.
To delete a record, you must know which node contains the record, and the record's sequence number. Use the event mailhistory show command to view this information.
-node {<nodename>|local} - Node
Use this parameter to specify the name of the node that contains the e-mail history record to delete.
-seqnum <Sequence Number> - Sequence Number
Use this parameter to specify the sequence number of the e-mail history record to delete.
The following example deletes all mail-history records on node1:
cluster1::> event mailhistory delete -node node1 -seqnum *
