security login publickey modify
Modify a public key
The security login publickey modify
command modifies a public key and optionally its comment text.
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver for the user associated with the public key.
-username <text>
- Username-
Specifies the username for the public key. If you do not specify a username, the username 'admin' is used by default.
-index <integer>
- Index-
Specifies the index number of the public key. The index number of the public key can be found by using the security login publickey show command.
[-publickey <certificate>]
- Public Key-
Specifies the new public key. You must enclose the new public key in double quotation marks.
[-comment <text>]
- Comment-
Specifies the new comment text for the public key.
The following command modifies the public key at index number 10 for the user named tsmith of Vserver vs1.
cluster1::> security login publickey modify -vserver vs1 -username tsmith -index 10 -publickey "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDDD+pFzFgV/2dlowKRFgym9K910H/u+BVTGitCtHteHyo8thmaXT 1GLCzaoC/12+XXiYKMRhJ00S9Svo4QQKUXHdCPXFSgR5PnAs39set39ECCLzmduplJnkWtX96pQH/bg2g3upFcdC6z9 c37uqFtNVPfv8As1Si/9WDQmEJ2mRtJudJeU5GZwZw5ybgTaN1jxDWus9SO2C43F/vmoCKVT529UHt4/ePcaaHOGTiQ O8+Qmm59uTgcfnpg53zYkpeAQV8RdYtMdWlRr44neh1WZrmW7x5N4nXNvtEzr9cvb9sJyqTX1CkQGfDOdb+7T7y3X7M if/qKQY6FsovjvfZD"
