statistics samples delete
Delete statistics samples
This command deletes samples that you created using the statistics start command.
-vserver <vserver name>
- Vserver-
Selects the Vserver for which you want to delete the sample. The default Vserver is admin Vserver.
-sample-id <text>
- Sample Identifier-
Specifies the sample that you want to delete. This is a required parameter.
The following example deletes the sample "smpl_1":
cluster1::*> statistics samples delete -sample-id smpl_1
